Introducción
If your laptop is running slowly, or crashing unexpectedly, the issue could be with faulty or insufficient RAM. Use this guide to upgrade or replace the laptop’s RAM. The RAM replacement is fairly simple on this laptop because it doesn’t require a full disassembly.
Partes
No se requieren partes.
  1. Flip the laptop bottom side up.
    • Flip the laptop bottom side up.
  2. Slide the battery lock to show the red background.
    • Slide the battery lock to show the red background.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Push the battery slider to the other side. This will automatically eject the battery. You can now  remove the battery.
    • Push the battery slider to the other side. This will automatically eject the battery.
    • You can now remove the battery.
  5. Remove the two 6.0mm Phillips #00 screws from the back cover.
    • Remove the two 6.0mm Phillips #00 screws from the back cover.
  6. Remove the back cover by placing the plastic opening tool in the indention, and prying upwards. Remove the back cover by placing the plastic opening tool in the indention, and prying upwards. Remove the back cover by placing the plastic opening tool in the indention, and prying upwards.
    • Remove the back cover by placing the plastic opening tool in the indention, and prying upwards.
  7. Hold back the plastic that protects the RAM so you can access the clips underneath. Gently push the holding clips outwards. The RAM will angle itself upwards.
    • Hold back the plastic that protects the RAM so you can access the clips underneath.
    • Gently push the holding clips outwards. The RAM will angle itself upwards.
    • Gently remove the RAM from the laptop
    • Make sure not to touch any part of the RAM except the sides.
    • When reassembling, insert the RAM into the connector, and then push it down until the clips lock it into place
Conclusión
Una persona más ha completado esta guía.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 69
