Saltar al contenido principal
Gateway NV55C49u Battery Replacement
Qué necesitas
  1. Gateway NV55C49u Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u Battery Replacement: paso 2, imagen 1 de 1
    • Switch the battery lock to show a red background with an unlock symbol
  3. Gateway NV55C49u Battery Replacement: paso 3, imagen 1 de 2 Gateway NV55C49u Battery Replacement: paso 3, imagen 2 de 2
    • Flip the switch with the battery symbol on it.
    • The battery should eject if done correctly.
  4. Gateway NV55C49u Battery Replacement: paso 4, imagen 1 de 1
    • Remove the battery by lifting the battery out.
  5. Gateway NV55C49u Battery Replacement: paso 5, imagen 1 de 1
    • This battery contains harmful chemicals, so it must be disposed of properly. Please take the old battery to a waste disposal center or recycling center.
    • Tip: in France, you can dispose of the old battery in the battery disposal points that can be found in a lot of supermarkets.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 309
