Saltar al contenido principal
Gateway NV53A24u Fan Replacement
Qué necesitas
  1. Gateway NV53A24u Fan Replacement, Fan: paso 1, imagen 1 de 2 Gateway NV53A24u Fan Replacement, Fan: paso 1, imagen 2 de 2
    • Locate the top of the keyboard, then insert a spudger into the top most edge of the keyboard where it meets the bezel surrounding it.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but a regular black nylon spudger should be used whenever possible.
  2. Gateway NV53A24u Fan Replacement: paso 2, imagen 1 de 1
    • Using the spudger, lift the keyboard from its base to expose the underside components.
  3. Gateway NV53A24u Fan Replacement: paso 3, imagen 1 de 2 Gateway NV53A24u Fan Replacement: paso 3, imagen 2 de 2
    • Using a #4 phillips screwdriver, remove all six 2.3mm screws from the plastic shroud.
    • Then, lift off the shroud to reveal the motherboard beneath.
  4. Gateway NV53A24u Fan Replacement: paso 4, imagen 1 de 2 Gateway NV53A24u Fan Replacement: paso 4, imagen 2 de 2
    • The motherboard is now readily accessible to be removed.
    • Using a spudger, gently pry the ports away from their side port containers to easily remove it.
  5. Gateway NV53A24u Fan Replacement: paso 5, imagen 1 de 2 Gateway NV53A24u Fan Replacement: paso 5, imagen 2 de 2
    • Lift the motherboard up and flip it on its back.
    • With the motherboard flipped, the fan is almost ready to be removed.
  6. Gateway NV53A24u Fan Replacement: paso 6, imagen 1 de 2 Gateway NV53A24u Fan Replacement: paso 6, imagen 2 de 2
    • Locate the fan and its copper heat pipe running just behind it.
    • Remove the fan from the heat pipe using slight force as it is held to the pipe with an adhesive tape.
Conclusión
Minh Harper
Miembro Desde 10/11/16
156 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-5, Leahy Fall 2016 Miembro de USF Tampa, Team 1-5, Leahy Fall 2016
USFT-LEAHY-F16S1G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 606
