Saltar al contenido principal
Gateway NV52 WiFi Card Replacement
Qué necesitas
  1. Gateway NV52 WiFi Card Replacement, Base Cover: paso 1, imagen 1 de 1
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 WiFi Card Replacement: paso 2, imagen 1 de 1
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 WiFi Card Replacement, WiFi Card: paso 3, imagen 1 de 1
    • Remove the 3/16" screw located at the bottom left corner of the WiFi card using a Phillips #0 Screwdriver.
  4. Gateway NV52 WiFi Card Replacement: paso 4, imagen 1 de 1
    • Locate the black and white cables attached to the WiFi card.
    • Gently wiggle the black cable until it detaches from the WiFi card.
    • Repeat the previous step for the white cable.
  5. Gateway NV52 WiFi Card Replacement: paso 5, imagen 1 de 1
    • Gently, remove the Wifi card from its slot, and place it in a dry and safe place.
Conclusión
Ruben
Miembro Desde 04/22/14
298 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 7-24, Regan Spring 2014 Miembro de Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 1,276
