Saltar al contenido principal
Gateway NV52 Hard Drive Replacement
Qué necesitas
  1. Gateway NV52 Hard Drive Replacement, Base Cover: paso 1, imagen 1 de 1
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 Hard Drive Replacement, Hard Drive Compartment: paso 3, imagen 1 de 1
    • Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
  4. Gateway NV52 Hard Drive Replacement: paso 4, imagen 1 de 3 Gateway NV52 Hard Drive Replacement: paso 4, imagen 2 de 3 Gateway NV52 Hard Drive Replacement: paso 4, imagen 3 de 3
    • Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
    • Lift the Hard Drive to a 90 degree angle and out of its slot.
    • Place the Hard Drive in a designated zone.
  5. Gateway NV52 Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 1
    • Remove the four identical 1/8" Phillip screws located in every corner of the Hard Drive using the Phillips #0 Screwdriver.
  6. Gateway NV52 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Access to the Hard drive by gently sliding the metal cover away from the Hard Drive.
Conclusión
Irma Marin
Miembro Desde 04/10/14
608 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 7-24, Regan Spring 2014 Miembro de Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 18
Todo El Tiempo: 3,535
