Saltar al contenido principal
Gateway NV52 Hard Drive Compartment Replacement
Qué necesitas
  1. Gateway NV52 Hard Drive Compartment Replacement, Base Cover: paso 1, imagen 1 de 1
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 Hard Drive Compartment Replacement: paso 2, imagen 1 de 1
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 Hard Drive Compartment Replacement, Hard Drive Compartment: paso 3, imagen 1 de 1
    • Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
  4. Gateway NV52 Hard Drive Compartment Replacement: paso 4, imagen 1 de 3 Gateway NV52 Hard Drive Compartment Replacement: paso 4, imagen 2 de 3 Gateway NV52 Hard Drive Compartment Replacement: paso 4, imagen 3 de 3
    • Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
    • Lift the Hard Drive to a 90 degree angle and out of its slot.
    • Place the Hard Drive in a designated zone.
Conclusión
2 personas más completaron esta guía.
Tim En
Miembro Desde 01/26/13
557 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 7-24, Regan Spring 2014 Miembro de Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 8
Todo El Tiempo: 971
