Introducción
As your laptop ages, drops, spills, and time can cause damage to your laptop screen. If the image is often distorted, the LD light is corrupt, or just a blatant crack in the screen, you can follow these steps to easily replace your screen. Replacing the screen will allow for a better image as well as an easier use of your device, without the frustration of looking at an unsatisfactory display.
Qué necesitas
Using the spudger, remove the protective caps for the screen to expose the screws.
Using the Phillips #000 screwdriver, unscrew the bottom two 1mm screws.
Una persona más ha completado esta guía.
