Saltar al contenido principal
Gateway NE56R27u Screen Replacement
Qué necesitas
  1. Gateway NE56R27u Screen Replacement, Battery: paso 1, imagen 1 de 2 Gateway NE56R27u Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Using the spudger, push the orange tab to the unlock position.
  2. Gateway NE56R27u Screen Replacement: paso 2, imagen 1 de 2 Gateway NE56R27u Screen Replacement: paso 2, imagen 2 de 2
    • Lift the battery from its compartment.
    • When reinstalling, insert back end of battery first, then clicking into place.
  3. Gateway NE56R27u Screen Replacement, Screen: paso 3, imagen 1 de 3 Gateway NE56R27u Screen Replacement, Screen: paso 3, imagen 2 de 3 Gateway NE56R27u Screen Replacement, Screen: paso 3, imagen 3 de 3
    • Using the spudger, remove the protective caps for the screen to expose the screws.
    • Using the Phillips #000 screwdriver, unscrew the bottom two 1mm screws.
  4. Gateway NE56R27u Screen Replacement: paso 4, imagen 1 de 3 Gateway NE56R27u Screen Replacement: paso 4, imagen 2 de 3 Gateway NE56R27u Screen Replacement: paso 4, imagen 3 de 3
    • Using the opening pick in between the front cover and bezel, gently loosen and lift the plastic bezel from the screen and backing.
  5. Gateway NE56R27u Screen Replacement: paso 5, imagen 1 de 2 Gateway NE56R27u Screen Replacement: paso 5, imagen 2 de 2
    • Gently lift the frame of the screen from the top to unhook the frame from the base.
    • When reassembling, hook the bottom of the screen to the base of the laptop before snapping into place.
  6. Gateway NE56R27u Screen Replacement: paso 6, imagen 1 de 3 Gateway NE56R27u Screen Replacement: paso 6, imagen 2 de 3 Gateway NE56R27u Screen Replacement: paso 6, imagen 3 de 3
    • Using the Phillips #000 screwdriver, unscrew the four 1 mm screws in the front corners of the metal frame.
    • Lift the screen slightly to expose the connector board.
  7. Gateway NE56R27u Screen Replacement: paso 7, imagen 1 de 2 Gateway NE56R27u Screen Replacement: paso 7, imagen 2 de 2
    • Using the spudger, carefully remove the webcam connector from the metal frame.
  8. Gateway NE56R27u Screen Replacement: paso 8, imagen 1 de 2 Gateway NE56R27u Screen Replacement: paso 8, imagen 2 de 2
    • Peel the tape covering the display cable, releasing the wire from the metal frame.
    • Unplug the display cable from the image processing board on the screen.
  9. Gateway NE56R27u Screen Replacement: paso 9, imagen 1 de 2 Gateway NE56R27u Screen Replacement: paso 9, imagen 2 de 2
    • Using the Phillips #000 screwdriver, unscrew the four 1 mm screws from the sides of the metal frame.
    • Remove the screen from the metal frame.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 225
