Saltar al contenido principal
Gateway NE56R27u Keyboard Replacement
Qué necesitas
  1. Gateway NE56R27u Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Gateway NE56R27u Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Using the spudger, push the orange tab to the unlock position.
  2. Gateway NE56R27u Keyboard Replacement: paso 2, imagen 1 de 2 Gateway NE56R27u Keyboard Replacement: paso 2, imagen 2 de 2
    • Lift the battery from its compartment.
    • When reinstalling, insert back end of battery first, then clicking into place.
  3. Gateway NE56R27u Keyboard Replacement, Hard Drive: paso 3, imagen 1 de 3 Gateway NE56R27u Keyboard Replacement, Hard Drive: paso 3, imagen 2 de 3 Gateway NE56R27u Keyboard Replacement, Hard Drive: paso 3, imagen 3 de 3
    • Unscrew the two 7.9mm Phillips #0 screws that secure the service cover.
  4. Gateway NE56R27u Keyboard Replacement: paso 4, imagen 1 de 2 Gateway NE56R27u Keyboard Replacement: paso 4, imagen 2 de 2
    • Use the opening tool to gently pry open the compartment covering.
  5. Gateway NE56R27u Keyboard Replacement: paso 5, imagen 1 de 3 Gateway NE56R27u Keyboard Replacement: paso 5, imagen 2 de 3 Gateway NE56R27u Keyboard Replacement: paso 5, imagen 3 de 3
    • Unscrew the two 0.5mm screws from the hard drive brackets using the Phillips #0 screwdriver.
    • Pull the plastic tab attached to the hard drive to the right to remove the hard drive.
    • The hard drive plugs into the port on the left within the compartment. Be sure to gently remove the hard drive without damaging the port.
  6. Gateway NE56R27u Keyboard Replacement: paso 6, imagen 1 de 2 Gateway NE56R27u Keyboard Replacement: paso 6, imagen 2 de 2
    • Remove the hard drive by lifting up the right side, releasing the hard drive from the compartment clips on the left.
  7. Gateway NE56R27u Keyboard Replacement, Keyboard: paso 7, imagen 1 de 2 Gateway NE56R27u Keyboard Replacement, Keyboard: paso 7, imagen 2 de 2
    • Flip your laptop over to view the keyboard.
    • Using the spudger, push in the ten tabs at the edges of the keyboard.
  8. Gateway NE56R27u Keyboard Replacement: paso 8, imagen 1 de 2 Gateway NE56R27u Keyboard Replacement: paso 8, imagen 2 de 2
    • Using the opening pick, lift the edges of the keyboard.
    • Repeat around the edges of the device.
    • Lift up the keyboard to expose the cables underneath.
  9. Gateway NE56R27u Keyboard Replacement: paso 9, imagen 1 de 3 Gateway NE56R27u Keyboard Replacement: paso 9, imagen 2 de 3 Gateway NE56R27u Keyboard Replacement: paso 9, imagen 3 de 3
    • Release the clamp holding the mini-DIN cord by lifting the two black tabs on either side.
    • Gently pull the mini-DIN cord out of the clamp.
    • Remove the keyboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 633
