Saltar al contenido principal
Gateway NE52214U Motherboard Replacement
Qué necesitas
  1. Gateway NE52214U Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure to power down and turn off the laptop before proceeding with this guide.
    • Flip over the laptop.
  2. Gateway NE52214U Motherboard Replacement: paso 2, imagen 1 de 2 Gateway NE52214U Motherboard Replacement: paso 2, imagen 2 de 2
    • Slide the tab to the left and hold the tab there.
    • While holding down the sliding tab, remove the battery from the device.
  3. Gateway NE52214U Motherboard Replacement, Upper Case: paso 3, imagen 1 de 2 Gateway NE52214U Motherboard Replacement, Upper Case: paso 3, imagen 2 de 2
    • After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
  4. Gateway NE52214U Motherboard Replacement: paso 4, imagen 1 de 1
    • Flip over the laptop and open it so the screen is facing you.
  5. Gateway NE52214U Motherboard Replacement: paso 5, imagen 1 de 1
    • Lift the upper case cover off of the device. Use a prying tool along the edges if necessary.
  6. Gateway NE52214U Motherboard Replacement, Motherboard: paso 6, imagen 1 de 1
    • Remove the twelve 3mm screws using the Phillips #00 screwdriver.
  7. Gateway NE52214U Motherboard Replacement: paso 7, imagen 1 de 2 Gateway NE52214U Motherboard Replacement: paso 7, imagen 2 de 2
    • Gently lift and remove the motherboard off of device.
    • This will also remove the fan from the device but it will remain attached to the motherboard.
Conclusión
Kelsey Rodrigues
Miembro Desde 10/23/18
495 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 319
