Introducción
Is your computer making loud noises and taking longer than normal to boot? Consider using this guide to replace the cooling fan in your device.
Qué necesitas
After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
Remove the four 3mm screws attaching the fan to motherboard using the Phillips #00 screwdriver.
Casi Terminas!
Conclusión
