Saltar al contenido principal
Gateway NE52214U Fan Replacement
Qué necesitas
  1. Gateway NE52214U Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure to power down and turn off the laptop before proceeding with this guide.
    • Flip over the laptop.
  2. Gateway NE52214U Fan Replacement: paso 2, imagen 1 de 2 Gateway NE52214U Fan Replacement: paso 2, imagen 2 de 2
    • Slide the tab to the left and hold the tab there.
    • While holding down the sliding tab, remove the battery from the device.
  3. Gateway NE52214U Fan Replacement, Upper Case: paso 3, imagen 1 de 2 Gateway NE52214U Fan Replacement, Upper Case: paso 3, imagen 2 de 2
    • After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
  4. Gateway NE52214U Fan Replacement: paso 4, imagen 1 de 1
    • Flip over the laptop and open it so the screen is facing you.
  5. Gateway NE52214U Fan Replacement: paso 5, imagen 1 de 1
    • Lift the upper case cover off of the device. Use a prying tool along the edges if necessary.
  6. Gateway NE52214U Fan Replacement, Motherboard: paso 6, imagen 1 de 1
    • Remove the twelve 3mm screws using the Phillips #00 screwdriver.
  7. Gateway NE52214U Fan Replacement: paso 7, imagen 1 de 2 Gateway NE52214U Fan Replacement: paso 7, imagen 2 de 2
    • Gently lift and remove the motherboard off of device.
    • This will also remove the fan from the device but it will remain attached to the motherboard.
  8. Gateway NE52214U Fan Replacement, Fan: paso 8, imagen 1 de 1
    • Remove the four 3mm screws attaching the fan to motherboard using the Phillips #00 screwdriver.
  9. Gateway NE52214U Fan Replacement: paso 9, imagen 1 de 2 Gateway NE52214U Fan Replacement: paso 9, imagen 2 de 2
    • Gently lift the fan and disconnect the fan from the motherboard.
    • Remove the fan from the device.
Conclusión
Kelsey Rodrigues
Miembro Desde 10/23/18
495 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 159
