Saltar al contenido principal
Gateway NE52203u USB Port Replacement
Qué necesitas
  1. Gateway NE52203u USB Port Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the device over onto its backside in order to access the battery.
  2. Gateway NE52203u USB Port Replacement: paso 2, imagen 1 de 2 Gateway NE52203u USB Port Replacement: paso 2, imagen 2 de 2
    • Locate the battery release latch and slide it over to the other side.
    • A small tool like a pen or screwdriver may be helpful in sliding the latch to release the battery.
  3. Gateway NE52203u USB Port Replacement: paso 3, imagen 1 de 1
    • Grab the newly ejected battery from the device to completely remove it.
    • When reinserting the new battery, make sure the prongs on the battery are aligned with the corresponding holes on the laptop.
  4. Gateway NE52203u USB Port Replacement, Touchpad Assembly: paso 4, imagen 1 de 2 Gateway NE52203u USB Port Replacement, Touchpad Assembly: paso 4, imagen 2 de 2
    • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
    • Remove 5 6.0 mm Phillip #00 screws from under cover.
  5. Gateway NE52203u USB Port Replacement: paso 5, imagen 1 de 1
    • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
  6. Gateway NE52203u USB Port Replacement: paso 6, imagen 1 de 2 Gateway NE52203u USB Port Replacement: paso 6, imagen 2 de 2
    • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
  7. Gateway NE52203u USB Port Replacement: paso 7, imagen 1 de 1
    • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
  8. Gateway NE52203u USB Port Replacement: paso 8, imagen 1 de 3 Gateway NE52203u USB Port Replacement: paso 8, imagen 2 de 3 Gateway NE52203u USB Port Replacement: paso 8, imagen 3 de 3
    • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
    • First flip open the flap covering the ribbon using a spudger or fingernail.
    • Second gently pull the ribbon away from the port.
  9. Gateway NE52203u USB Port Replacement, USB Port: paso 9, imagen 1 de 2 Gateway NE52203u USB Port Replacement, USB Port: paso 9, imagen 2 de 2
    • Using a spudger, pry the ZIF connector upwards.
  10. Gateway NE52203u USB Port Replacement: paso 10, imagen 1 de 1
    • Use your fingers to gently disconnect the ribbon wire from the USB circuit board.
  11. Gateway NE52203u USB Port Replacement: paso 11, imagen 1 de 1
    • Using a #00 Phillips head screwdriver, remove the 2.9 mm screw on the USB circuit board.
  12. Gateway NE52203u USB Port Replacement: paso 12, imagen 1 de 1
    • Finally, remove the old USB port.
Conclusión
3 personas más completaron esta guía.
Stephen Spees
Miembro Desde 03/20/15
542 Reputación
4 Guías creadas
Equipo
Baylor, Team 2-1, Grigsby Spring 2015 Miembro de Baylor, Team 2-1, Grigsby Spring 2015
BU-GRIGSBY-S15S2G1
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 642
