Saltar al contenido principal
Gateway NE51006u Battery Replacement
Qué necesitas
  1. Gateway NE51006u Battery Replacement, Battery: paso 1, imagen 1 de 2 Gateway NE51006u Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure your device is powered off before beginning this guide.
    • Place your device on your workspace, screen facing down. Take the Spudger and use the pointed end to catch the latch below the battery. Drag the latch to the right until the battery detaches from the body of the device.
  2. Gateway NE51006u Battery Replacement: paso 2, imagen 1 de 1
    • Pull the battery out, making sure to pull the battery parallel to the device.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 727
