Saltar al contenido principal
Gateway MS2370 Keyboard Replacement
Qué necesitas
  1. Gateway MS2370 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 Keyboard Replacement: paso 2, imagen 1 de 1
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 Keyboard Replacement: paso 3, imagen 1 de 1
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 1
    • Take the plastic spudger and pull up the tabs on all four sides of the keyboard molding.
  5. Gateway MS2370 Keyboard Replacement: paso 5, imagen 1 de 1
    • Carefully lift the keyboard molding out.
  6. Gateway MS2370 Keyboard Replacement: paso 6, imagen 1 de 1
    • Use the plastic spudger again to pry the keyboard tabs from the laptop.
  7. Gateway MS2370 Keyboard Replacement: paso 7, imagen 1 de 1
    • Slowly lift the keyboard from the laptop.
  8. Gateway MS2370 Keyboard Replacement: paso 8, imagen 1 de 2 Gateway MS2370 Keyboard Replacement: paso 8, imagen 2 de 2
    • Carefully unplug the ribbon cable attached to the motherboard.
    • The ribbon cable is extremely delicate, handle with care
  9. Gateway MS2370 Keyboard Replacement: paso 9, imagen 1 de 1
    • Lift and remove the keyboard from the computer.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 850
