Saltar al contenido principal
Gateway MS2370 Fan Replacement
Qué necesitas
  1. Gateway MS2370 Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 Fan Replacement: paso 2, imagen 1 de 1
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 Fan Replacement: paso 3, imagen 1 de 1
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 Fan Replacement, RAM: paso 4, imagen 1 de 1
    • Unscrew the three 10mm inch Phillips 01 screws on the back of your laptop.
    • Unplug everything from the USB and SD ports.
  5. Gateway MS2370 Fan Replacement: paso 5, imagen 1 de 1
    • Remove the cover panel.
    • This exposes more screws that must be removed.
  6. Gateway MS2370 Fan Replacement: paso 6, imagen 1 de 1
    • Unplug the two exposed cables from the motherboard.
  7. Gateway MS2370 Fan Replacement: paso 7, imagen 1 de 2 Gateway MS2370 Fan Replacement: paso 7, imagen 2 de 2
    • Unscrew the rest of the case screws which include several 10mm 01 Phillips screws and three 3mm 00 Phillips screws.
    • This marked screw will not fully come out. Just loosen it and leave it there it will not effect the rest of the replacement.
  8. Gateway MS2370 Fan Replacement: paso 8, imagen 1 de 2 Gateway MS2370 Fan Replacement: paso 8, imagen 2 de 2
    • Pry the laptop case apart.
    • The disc drive in this photo was removed. You can remove it just by puling it out when the previous step is completed.
  9. Gateway MS2370 Fan Replacement: paso 9, imagen 1 de 1
    • Unplug the track-pad and the keyboard ribbon cable by lifting up the grey flap and removing the cable.
    • This cable has a special connector the requires you to lift open a grey flap to unplug properly.
    • The keyboard plug is located at the center of the motherboard and can be unplugged like a normal cable.
  10. Gateway MS2370 Fan Replacement: paso 10, imagen 1 de 1
    • Remove the top half of the case.
  11. Gateway MS2370 Fan Replacement: paso 11, imagen 1 de 1
    • Unscrew all 5 10mm inch Phillips 01 screws.
    • One more off screen
  12. Gateway MS2370 Fan Replacement: paso 12, imagen 1 de 3 Gateway MS2370 Fan Replacement: paso 12, imagen 2 de 3 Gateway MS2370 Fan Replacement: paso 12, imagen 3 de 3
    • Unplug the ribbon cable connected to the USB Hub, the network card, and the monitor cable.
  13. Gateway MS2370 Fan Replacement: paso 13, imagen 1 de 1
    • Flip the motherboard over.
  14. Gateway MS2370 Fan Replacement: paso 14, imagen 1 de 3 Gateway MS2370 Fan Replacement: paso 14, imagen 2 de 3 Gateway MS2370 Fan Replacement: paso 14, imagen 3 de 3
    • Using your two thumbs to pull outwards from the inside of the RAM slot to release and remove the RAM.
    • The last step of this replacement guide is not required to complete the fan replacement guide.
  15. Gateway MS2370 Fan Replacement, Fan: paso 15, imagen 1 de 1
    • Unscrew the three 3mm inch Phillips 01 screws.
    • These screws will not be removed entirely. Just loosen them enough to free the fan from the motherboard.
  16. Gateway MS2370 Fan Replacement: paso 16, imagen 1 de 1
    • Unplug the fan cable from the motherboard.
  17. Gateway MS2370 Fan Replacement: paso 17, imagen 1 de 1
    • Remove the Fan.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 561
