Saltar al contenido principal
Gateway MS2285 Battery Replacement
  1. Gateway MS2285 Battery Replacement, Turn Laptop Over: paso 1, imagen 1 de 1
    • Turn the laptop over so that the underside is facing towards you.
  2. Gateway MS2285 Battery Replacement, Unlock The Battery: paso 2, imagen 1 de 2 Gateway MS2285 Battery Replacement, Unlock The Battery: paso 2, imagen 2 de 2
    • Slide the short slider one towards the unlocked lock symbol.
  3. Gateway MS2285 Battery Replacement, Release The Battery: paso 3, imagen 1 de 2 Gateway MS2285 Battery Replacement, Release The Battery: paso 3, imagen 2 de 2
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
  4. Gateway MS2285 Battery Replacement, Remove The Battery: paso 4, imagen 1 de 2 Gateway MS2285 Battery Replacement, Remove The Battery: paso 4, imagen 2 de 2
    • Grasp the battery's raised end and lift upwards.
Conclusión
Chris mello
Miembro Desde 10/22/14
331 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 1-7, Shastany Fall 2014 Miembro de UMass Dartmouth, Team 1-7, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G7
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 19
Todo El Tiempo: 1,249
