Saltar al contenido principal
Gateway MD2614u Wireless Card Replacement
Qué necesitas
  1. Gateway MD2614u Wireless Card Replacement, Back Cover: paso 1, imagen 1 de 1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Wireless Card Replacement: paso 2, imagen 1 de 1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Wireless Card Replacement: paso 3, imagen 1 de 1
    • Lift off the cover.
  4. Gateway MD2614u Wireless Card Replacement, Wireless Card: paso 4, imagen 1 de 1
    • The wireless card is located to the right of the hard drive and below the RAM.
  5. Gateway MD2614u Wireless Card Replacement: paso 5, imagen 1 de 1
    • There are black and grey wires with gold heads attached to the top of the wireless card.
    • To remove these wires, turn the gold heads counterclockwise and pull up.
    • You will hear a snap when the heads come off.
    • It does not matter which wire you remove first, but do so one at a time.
  6. Gateway MD2614u Wireless Card Replacement: paso 6, imagen 1 de 1
    • Remove the two screws next to the wires with a Phillips #00 screwdriver.
  7. Gateway MD2614u Wireless Card Replacement: paso 7, imagen 1 de 1
    • The card will pop up 20 degrees and is loose enough to remove with your hand.
    • Carefully pull the card out to the left horizontally.
Conclusión
Toni Pipes
Miembro Desde 10/05/10
333 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 21-31, Regan Fall 2010 Miembro de Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 30
Todo El Tiempo: 4,252
