Saltar al contenido principal
Gateway MD2614u Processor Replacement
Qué necesitas
  1. Gateway MD2614u Processor Replacement, Back Cover: paso 1, imagen 1 de 1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Processor Replacement: paso 2, imagen 1 de 1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Processor Replacement: paso 3, imagen 1 de 1
    • Lift off the cover.
  4. Gateway MD2614u Processor Replacement, Fan: paso 4, imagen 1 de 1
    • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
    • Pull the plastic part of the cable, not the wires, so that the plug does not break.
  5. Gateway MD2614u Processor Replacement: paso 5, imagen 1 de 1
    • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
  6. Gateway MD2614u Processor Replacement: paso 6, imagen 1 de 1
    • The fan is permanently attached to the silver heat sink next to the RAM.
    • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
    • Take out the screws in the numerical order shown on the heat sink.
  7. Gateway MD2614u Processor Replacement: paso 7, imagen 1 de 1
    • Pull the fan and heat sink toward you at a 20 degree angle upward.
  8. Gateway MD2614u Processor Replacement, Processor: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Comprar
    • The CPU is located under the heat sink you just removed.
    • It is a green card on a white plastic surface. There is a black lock on one side of the plastic.
    • Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screwdriver.
    • If done correctly, the lock makes a clicking noise when unlocked.
  9. Gateway MD2614u Processor Replacement: paso 9, imagen 1 de 1
    • Place your fingers on opposite edges of the green card.
    • Carefully lift the CPU upward.
Conclusión
2 personas más completaron esta guía.
Toni Pipes
Miembro Desde 10/05/10
333 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 21-31, Regan Fall 2010 Miembro de Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Miembros
14 Guías creadas
Un comentario
Memory address registers and memory data registers together can represent the gateway?if can how?
Jayita Roy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 7,194
