Saltar al contenido principal
Gateway MD2614u Internal Modem Replacement
Qué necesitas
  1. Gateway MD2614u Internal Modem Replacement, Back Cover: paso 1, imagen 1 de 1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Internal Modem Replacement: paso 2, imagen 1 de 1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Internal Modem Replacement: paso 3, imagen 1 de 1
    • Lift off the cover.
  4. Gateway MD2614u Internal Modem Replacement, Internal Modem: paso 4, imagen 1 de 1
    • The internal modem will be located towards the bottom right of the laptop (highlighted with a yellow square).
  5. Gateway MD2614u Internal Modem Replacement: paso 5, imagen 1 de 1
    • Using a Phillips #00 screwdriver, unscrew both of the screws that are holding the modem in place.
  6. Gateway MD2614u Internal Modem Replacement: paso 6, imagen 1 de 1
    • Carefully pry the modem as to not damage any of the surrounding components
  7. Gateway MD2614u Internal Modem Replacement: paso 7, imagen 1 de 1
    • Using needle nose pliers, carefully detach the wire connecting the modem, by applying pressure to the black tabs away from the modem itself.
  8. Gateway MD2614u Internal Modem Replacement: paso 8, imagen 1 de 1
    • Success! You've removed the internal modem!
Conclusión
Nelson
Miembro Desde 03/11/14
201 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 395
