Saltar al contenido principal
Gateway MD2614u Battery Replacement
  1. Gateway MD2614u Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure the laptop is completely powered off and disconnected from any power source. Turn your Gateway MD2614U laptop over as shown in the image.
  2. Gateway MD2614u Battery Replacement: paso 2, imagen 1 de 1
    • Slide and hold the battery release lock to the left.
  3. Gateway MD2614u Battery Replacement: paso 3, imagen 1 de 1
    • Pull the battery away from the laptop.
  4. Gateway MD2614u Battery Replacement: paso 4, imagen 1 de 1
    • Insert the new battery into the slot.
Conclusión
To reassemble your Gateway MD2614u laptop after replacing the battery, follow the reverse sequence of the steps you took during the initial battery assembly.
Toni Pipes
Miembro Desde 10/05/10
333 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 21-31, Regan Fall 2010 Miembro de Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 3,923
