Saltar al contenido principal
Gateway MA6 Laptop RAM Replacement
Qué necesitas
  1. Gateway MA6 Laptop RAM Replacement, Battery: paso 1, imagen 1 de 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Gateway MA6 Laptop RAM Replacement: paso 2, imagen 1 de 3 Gateway MA6 Laptop RAM Replacement: paso 2, imagen 2 de 3 Gateway MA6 Laptop RAM Replacement: paso 2, imagen 3 de 3
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Gateway MA6 Laptop RAM Replacement, RAM: paso 3, imagen 1 de 2 Gateway MA6 Laptop RAM Replacement, RAM: paso 3, imagen 2 de 2
    • Remove the seven 6 mm Phillips #0 screws from the back of the case.
    • Leave all the screws in the back plate and so you don't lose them.
  4. Gateway MA6 Laptop RAM Replacement: paso 4, imagen 1 de 2 Gateway MA6 Laptop RAM Replacement: paso 4, imagen 2 de 2
    • Pull upwards on the top of the back cover to remove it.
  5. Gateway MA6 Laptop RAM Replacement: paso 5, imagen 1 de 3 Gateway MA6 Laptop RAM Replacement: paso 5, imagen 2 de 3 Gateway MA6 Laptop RAM Replacement: paso 5, imagen 3 de 3
    • Pull outwards on the silver metal pins to release the upper RAM module.
    • The module will automatically lift up 30° after it has been released.
  6. Gateway MA6 Laptop RAM Replacement: paso 6, imagen 1 de 2 Gateway MA6 Laptop RAM Replacement: paso 6, imagen 2 de 2
    • Firmly grasp the outer portion of the RAM module, and pull it outward to remove it from the port.
    • Repeat the same process for the lower RAM module.
Conclusión
Chris Naughton
Miembro Desde 04/07/14
705 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-2, Forte Spring 2014 Miembro de Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 1,164
