Saltar al contenido principal
Gateway MA6 Laptop Cooling Assembly Replacement
Qué necesitas
  1. Gateway MA6 Laptop Cooling Assembly Replacement, Cooling Assembly: paso 1, imagen 1 de 2 Gateway MA6 Laptop Cooling Assembly Replacement, Cooling Assembly: paso 1, imagen 2 de 2
    • Loosen the seven 6 mm Phillips #0 screws on the back of the case.
    • Leave all the screws in the back plate and so you don't lose them.
  2. Gateway MA6 Laptop Cooling Assembly Replacement: paso 2, imagen 1 de 2 Gateway MA6 Laptop Cooling Assembly Replacement: paso 2, imagen 2 de 2
    • Pull upwards on the top of the back cover to remove it.
  3. Gateway MA6 Laptop Cooling Assembly Replacement: paso 3, imagen 1 de 1
    • Remove the four 9 mm Phillips #0 screws from the cooling assembly.
  4. Gateway MA6 Laptop Cooling Assembly Replacement: paso 4, imagen 1 de 3 Gateway MA6 Laptop Cooling Assembly Replacement: paso 4, imagen 2 de 3 Gateway MA6 Laptop Cooling Assembly Replacement: paso 4, imagen 3 de 3
    • Gently and carefully remove the cooling assembly to avoid ripping the wire attaching it to the computer.
    • Gently flip the cooling fan assembly upside-down on the computer surface.
    • Carefully grab the wire attached to the computer and pull away from the port.
    • The cooling fan is now safe for removal.
  5. Gateway MA6 Laptop Cooling Assembly Replacement: paso 5, imagen 1 de 1
    • When reinstalling heat sink and fans clean off the old thermal paste from both the heat sink and the CPU and then add new paste to CPU
    • If your unfamiliar with applying thermal paste Cómo aplicar pasta térmica
Conclusión
2 personas más completaron esta guía.
Chris Naughton
Miembro Desde 04/07/14
705 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-2, Forte Spring 2014 Miembro de Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 782
