Saltar al contenido principal
Gateway M-2626u RAM Replacement
Qué necesitas
  1. Gateway M-2626u RAM  Replacement, Battery: paso 1, imagen 1 de 1
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u RAM  Replacement: paso 2, imagen 1 de 3 Gateway M-2626u RAM  Replacement: paso 2, imagen 2 de 3 Gateway M-2626u RAM  Replacement: paso 2, imagen 3 de 3
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u RAM  Replacement, Back Panel: paso 3, imagen 1 de 2 Gateway M-2626u RAM  Replacement, Back Panel: paso 3, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  4. Gateway M-2626u RAM  Replacement: paso 4, imagen 1 de 2 Gateway M-2626u RAM  Replacement: paso 4, imagen 2 de 2
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
  5. Gateway M-2626u RAM  Replacement, RAM: paso 5, imagen 1 de 1
    • Remember to always remove or disconnect the battery!
    • Push outwards on the metal tab to unlock the RAM stick from its position.
  6. Gateway M-2626u RAM  Replacement: paso 6, imagen 1 de 2 Gateway M-2626u RAM  Replacement: paso 6, imagen 2 de 2
    • Lift up and remove the RAM from the device.
    • Follow the same steps to remove the second RAM stick from your device.
Conclusión
Tanya Jain
Miembro Desde 03/19/18
317 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 136
