Saltar al contenido principal
Gateway M-2626u Hard Drive Replacement
Qué necesitas
  1. Gateway M-2626u Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u Hard Drive Replacement: paso 2, imagen 1 de 3 Gateway M-2626u Hard Drive Replacement: paso 2, imagen 2 de 3 Gateway M-2626u Hard Drive Replacement: paso 2, imagen 3 de 3
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 2 Gateway M-2626u Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the three 6mm screws holding the hard drive panel in place.
  4. Gateway M-2626u Hard Drive Replacement: paso 4, imagen 1 de 1
    • Using the plastic opening tool, pry open the plastic panel covering the hard drive.
  5. Gateway M-2626u Hard Drive Replacement: paso 5, imagen 1 de 3 Gateway M-2626u Hard Drive Replacement: paso 5, imagen 2 de 3 Gateway M-2626u Hard Drive Replacement: paso 5, imagen 3 de 3
    • Using your hands, carefully pull out the hard drive from its compartment.
Conclusión
Femi
Miembro Desde 04/06/18
219 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 211
