Saltar al contenido principal
Gateway M-2626u Battery Replacement
  1. Gateway M-2626u  Battery Replacement, Battery: paso 1, imagen 1 de 1
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u  Battery Replacement: paso 2, imagen 1 de 3 Gateway M-2626u  Battery Replacement: paso 2, imagen 2 de 3 Gateway M-2626u  Battery Replacement: paso 2, imagen 3 de 3
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
Conclusión
Tanya Jain
Miembro Desde 03/19/18
317 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 232
