Saltar al contenido principal
Gateway LT41P10u Keyboard Replacement
Qué necesitas
  1. Gateway LT41P10u Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Place the laptop upside down on a flat surface so you can see the battery.
  2. Gateway LT41P10u Keyboard Replacement: paso 2, imagen 1 de 1
    • Pull the two marked tabs towards the outside of the computer to unlock them.
  3. Gateway LT41P10u Keyboard Replacement: paso 3, imagen 1 de 1
    • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
  4. Gateway LT41P10u Keyboard Replacement, Keyboard: paso 4, imagen 1 de 2 Gateway LT41P10u Keyboard Replacement, Keyboard: paso 4, imagen 2 de 2
    • Once the battery is removed, flip the laptop over and open it up so you can see the keyboard.
    • Underneath the f4, f8, and f12 keys there are indents (see the second image) to fit a spudger or plastic opening tool to pop the keyboard off.
    • Once you find an indent with your spudger, carefully move it so the top of the keyboard comes away from the rest of the computer, followed by the bottom of the keyboard.
  5. Gateway LT41P10u Keyboard Replacement: paso 5, imagen 1 de 1
    • Once you pull the keyboard off, you will see a ribbon wire connecting the keyboard to the rest of the laptop.
    • To detach the keyboard from the rest of the computer, you have to unlock the ribbon by pulling up on the small black lock keeping the ribbon from being removed. You won't have to pull very hard, so be gentle to avoid damaging it.
    • Once the ribbon is disconnected from the computer, you are able to pull the ribbon out from underneath the lock, and then pull the keyboard away.
Conclusión
To reinstall your keyboard, follow these instructions in reverse order.
Michael Smith
Miembro Desde 10/19/17
401 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 384
