Saltar al contenido principal
Gateway LT4004u Screen Replacement
Qué necesitas
  1. Gateway LT4004u Screen Replacement, Screen: paso 1, imagen 1 de 3 Gateway LT4004u Screen Replacement, Screen: paso 1, imagen 2 de 3 Gateway LT4004u Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Open the laptop so that the screen and keyboard are facing you.
    • Remove the two screw covers at the bottom right and left corners of the screen using tweezers.
  2. Gateway LT4004u Screen Replacement: paso 2, imagen 1 de 3 Gateway LT4004u Screen Replacement: paso 2, imagen 2 de 3 Gateway LT4004u Screen Replacement: paso 2, imagen 3 de 3
    • Unscrew the two 5.0mm screws underneath the screen covers on the left and right side and remove them from the laptop. For this step and the following steps, use a Phillips #0 head screwdriver.
  3. Gateway LT4004u Screen Replacement: paso 3, imagen 1 de 3 Gateway LT4004u Screen Replacement: paso 3, imagen 2 de 3 Gateway LT4004u Screen Replacement: paso 3, imagen 3 de 3
    • Once the two screws are removed, pry the screen casing away from the screen. You can use your fingernails or a tool such as tweezers to separate the screen casing from the backing.
    • Be prepared to hear cracking noises. These are expected.
    • Unhook the screen casing at the bottom of the screen from the central hinges on the left and right side connecting the screen casing to the keyboard.
    • Remove the screen casing.
  4. Gateway LT4004u Screen Replacement: paso 4, imagen 1 de 3 Gateway LT4004u Screen Replacement: paso 4, imagen 2 de 3 Gateway LT4004u Screen Replacement: paso 4, imagen 3 de 3
    • Once the screen casing is removed, unscrew the 8 screws surrounding the screen and remove them from the laptop. All 8 screws should measure 4.0mm long.
    • There is a single screw in each red indicator and two screws in each orange indicator, totaling to the eight screws.
  5. Gateway LT4004u Screen Replacement: paso 5, imagen 1 de 3 Gateway LT4004u Screen Replacement: paso 5, imagen 2 de 3 Gateway LT4004u Screen Replacement: paso 5, imagen 3 de 3
    • Unplug the webcam connection from the top of the laptop screen backing.
  6. Gateway LT4004u Screen Replacement: paso 6, imagen 1 de 3 Gateway LT4004u Screen Replacement: paso 6, imagen 2 de 3 Gateway LT4004u Screen Replacement: paso 6, imagen 3 de 3
    • Flip the screen over so that it is lying on top of the keyboard.
    • Looking at the underside of the screen, remove the yellow tape and carefully remove the wires attaching the screen to the laptop.
  7. Gateway LT4004u Screen Replacement: paso 7, imagen 1 de 1
    • Remove the screen from the rest of the laptop.
Conclusión
Una persona más ha completado esta guía.
Equipo
Clemson, Team 6-5, Benson Spring 2016 Miembro de Clemson, Team 6-5, Benson Spring 2016
CLEM-BENSON-S16S6G5
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 477
