Saltar al contenido principal
Gateway LT4004u Battery Replacement
  1. Gateway LT4004u Battery Replacement, Battery: paso 1, imagen 1 de 3 Gateway LT4004u Battery Replacement, Battery: paso 1, imagen 2 de 3 Gateway LT4004u Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Place the laptop face down in front of you.
    • Locate the battery lock switches on the left and right top corners of the bottom of the device indicated by the red circles.
    • Pinch the switches and slide toward the edges of the computer to unlock.
  2. Gateway LT4004u Battery Replacement: paso 2, imagen 1 de 2 Gateway LT4004u Battery Replacement: paso 2, imagen 2 de 2
    • Once the switches have both been unlocked, push the battery upwards away from the rest of the laptop.
    • Remove the battery from the laptop.
Conclusión
Equipo
Clemson, Team 6-5, Benson Spring 2016 Miembro de Clemson, Team 6-5, Benson Spring 2016
CLEM-BENSON-S16S6G5
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 605
