Saltar al contenido principal
Gateway LT2514u Battery Replacement
Qué necesitas
  1. Gateway LT2514u Battery Replacement, Battery: paso 1, imagen 1 de 2 Gateway LT2514u Battery Replacement, Battery: paso 1, imagen 2 de 2
    • With the netbook's lid closed, flip it over and slide the latch on the upper left hand side of the netbook to the left.
    • You should see an orange indicator when the battery is unlocked.
  2. Gateway LT2514u Battery Replacement: paso 2, imagen 1 de 2 Gateway LT2514u Battery Replacement: paso 2, imagen 2 de 2
    • In the upper right-hand corner of the netbook, slide and hold the switch to the right.
    • Use your other hand to slide out the battery.
    • If the release switch in the upper right-hand area is missing, you can still remove the battery by following Step 3. Otherwise, skip it.
  3. Gateway LT2514u Battery Replacement: paso 3, imagen 1 de 3 Gateway LT2514u Battery Replacement: paso 3, imagen 2 de 3 Gateway LT2514u Battery Replacement: paso 3, imagen 3 de 3
    • If the release switch in the upper right-hand area is missing, insert a slender tool (we used tweezers) into the left side of the smaller hole.
    • Slide and hold the tweezers to the right and use your other hand to slide the battery out.
Conclusión
Una persona más ha completado esta guía.
Brian Garver
Miembro Desde 10/04/16
839 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 3-2, Sullivan Fall 2016 Miembro de USF Tampa, Team 3-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G2
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 327
