Saltar al contenido principal
Gateway KAV60 LT2016U Upper Cover Replacement
Qué necesitas
  1. Gateway KAV60 LT2016U Upper Cover Replacement, Battery: paso 1, imagen 1 de 3 Gateway KAV60 LT2016U Upper Cover Replacement, Battery: paso 1, imagen 2 de 3 Gateway KAV60 LT2016U Upper Cover Replacement, Battery: paso 1, imagen 3 de 3
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U Upper Cover Replacement, Upper Cover: paso 2, imagen 1 de 1
    • Make sure the RAM, hard drive, and WiFi card have been removed from the computer before trying to take off the cover so they are not damaged in the process.
  3. Gateway KAV60 LT2016U Upper Cover Replacement: paso 3, imagen 1 de 2 Gateway KAV60 LT2016U Upper Cover Replacement: paso 3, imagen 2 de 2
    • Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here.
  4. Gateway KAV60 LT2016U Upper Cover Replacement: paso 4, imagen 1 de 3 Gateway KAV60 LT2016U Upper Cover Replacement: paso 4, imagen 2 de 3 Gateway KAV60 LT2016U Upper Cover Replacement: paso 4, imagen 3 de 3
    • Pry up the keyboard using a spudger or plastic opening tool in the exact location shown in the photograph.
    • Don't use a screwdriver as a pry tool as shown in this example.
    • Carefully disconnect the keyboard ribbon cable from the motherboard, and remove the keyboard.
  5. Gateway KAV60 LT2016U Upper Cover Replacement: paso 5, imagen 1 de 1
    • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
  6. Gateway KAV60 LT2016U Upper Cover Replacement: paso 6, imagen 1 de 2 Gateway KAV60 LT2016U Upper Cover Replacement: paso 6, imagen 2 de 2
    • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
    • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
    • Carefully disconnect two ribbon cables to complete the separation of the upper cover.
Conclusión
Una persona más ha completado esta guía.
Lydia Benjock
Miembro Desde 10/18/13
1,216 Reputación
10 Guías creadas
Equipo
Clemson, Team 14-3, Benson Fall 2013 Miembro de Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 607
