Saltar al contenido principal
Gateway KAV60 LT2016U RAM Replacement
Qué necesitas
  1. Gateway KAV60 LT2016U RAM Replacement, Battery: paso 1, imagen 1 de 3 Gateway KAV60 LT2016U RAM Replacement, Battery: paso 1, imagen 2 de 3 Gateway KAV60 LT2016U RAM Replacement, Battery: paso 1, imagen 3 de 3
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U RAM Replacement, RAM: paso 2, imagen 1 de 1
    • The RAM is located under this cover.
  3. Gateway KAV60 LT2016U RAM Replacement: paso 3, imagen 1 de 3 Gateway KAV60 LT2016U RAM Replacement: paso 3, imagen 2 de 3 Gateway KAV60 LT2016U RAM Replacement: paso 3, imagen 3 de 3
    • Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place.
    • Use a plastic opening tool to remove the cover.
  4. Gateway KAV60 LT2016U RAM Replacement: paso 4, imagen 1 de 2 Gateway KAV60 LT2016U RAM Replacement: paso 4, imagen 2 de 2
    • Unlock the RAM by pinching the metal clamps that keep the RAM in place.
    • Remove the RAM while the metal clamps are disengaged.
Conclusión
Lydia Benjock
Miembro Desde 10/18/13
1,216 Reputación
10 Guías creadas
Equipo
Clemson, Team 14-3, Benson Fall 2013 Miembro de Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 2,085
