Introducción
Replacing the motherboard take quite a few steps, but it is doable.
Qué necesitas
Unlock the tab located in the top left corner of the netbook.
The red tab indicated that the battery has been properly unlocked.
Remove the battery.
Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
Carefully disconnect two ribbon cables to complete the separation of the upper cover.
The WiFi card is shown here.
Remove the one (1) 5mm screw holding the card to the motherboard using a Phillips #0 screwdriver.
Using a Phillips #00 screwdriver, remove the four (4) 5mm screws holding the motherboard in place.
Una persona más ha completado esta guía.
