Saltar al contenido principal
Gateway KAV60 LT2016U Hard Drive Replacement
Qué necesitas
  1. Gateway KAV60 LT2016U Hard Drive Replacement, Battery: paso 1, imagen 1 de 3 Gateway KAV60 LT2016U Hard Drive Replacement, Battery: paso 1, imagen 2 de 3 Gateway KAV60 LT2016U Hard Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U Hard Drive Replacement, Hard Drive: paso 2, imagen 1 de 1
    • The hard drive is located under this cover.
  3. Gateway KAV60 LT2016U Hard Drive Replacement: paso 3, imagen 1 de 2 Gateway KAV60 LT2016U Hard Drive Replacement: paso 3, imagen 2 de 2
    • Remove the two (2) 5mm screws holding the cover down using the Phillips #0 screwdriver.
  4. Gateway KAV60 LT2016U Hard Drive Replacement: paso 4, imagen 1 de 2 Gateway KAV60 LT2016U Hard Drive Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to lift the cover.
  5. Gateway KAV60 LT2016U Hard Drive Replacement: paso 5, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove a third 5mm screw that holds the second cover that is directly protecting the hard drive.
  6. Gateway KAV60 LT2016U Hard Drive Replacement: paso 6, imagen 1 de 3 Gateway KAV60 LT2016U Hard Drive Replacement: paso 6, imagen 2 de 3 Gateway KAV60 LT2016U Hard Drive Replacement: paso 6, imagen 3 de 3
    • Slide the silver cover up; the hole on the cover and the hole for the screw will no longer match up.
    • Lift the silver cover; this will expose the hard drive.
Conclusión
Lydia Benjock
Miembro Desde 10/18/13
1,216 Reputación
10 Guías creadas
Equipo
Clemson, Team 14-3, Benson Fall 2013 Miembro de Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 14
Todo El Tiempo: 1,655
