Saltar al contenido principal
Gateway ID49C07U Screen Replacement
Qué necesitas
  1. Gateway ID49C07U Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U Screen Replacement: paso 2, imagen 1 de 2 Gateway ID49C07U Screen Replacement: paso 2, imagen 2 de 2
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U Screen Replacement: paso 3, imagen 1 de 1
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U Screen Replacement: paso 4, imagen 1 de 1
    • While holding the release switch to the right, pull the battery away from you.
  5. Gateway ID49C07U Screen Replacement, Screen: paso 5, imagen 1 de 1
    • Turn the laptop over and open.
  6. Gateway ID49C07U Screen Replacement: paso 6, imagen 1 de 2 Gateway ID49C07U Screen Replacement: paso 6, imagen 2 de 2
    • Use the Small metal spudger to remove the small black screw covers in the bottom corners of the screen
  7. Gateway ID49C07U Screen Replacement: paso 7, imagen 1 de 2 Gateway ID49C07U Screen Replacement: paso 7, imagen 2 de 2
    • Use the PH1 Screwdriver to remove the screws
  8. Gateway ID49C07U Screen Replacement: paso 8, imagen 1 de 1
    • Use the small metal spudger to start separating the front plastic cover from the back plastic cover
  9. Gateway ID49C07U Screen Replacement: paso 9, imagen 1 de 3 Gateway ID49C07U Screen Replacement: paso 9, imagen 2 de 3 Gateway ID49C07U Screen Replacement: paso 9, imagen 3 de 3
    • Once there is enough room for you to fit your hand underneath the top plastic cover you can start pealing it back. It will make a lot of popping noises as it unclips when you separate it.
  10. Gateway ID49C07U Screen Replacement: paso 10, imagen 1 de 3 Gateway ID49C07U Screen Replacement: paso 10, imagen 2 de 3 Gateway ID49C07U Screen Replacement: paso 10, imagen 3 de 3
    • Once the plastic cover is off locate the 4 screws in the corners of the screen and unscrew them
  11. Gateway ID49C07U Screen Replacement: paso 11, imagen 1 de 2 Gateway ID49C07U Screen Replacement: paso 11, imagen 2 de 2
    • After the screws are out gently flip the screen over onto the keyboard
  12. Gateway ID49C07U Screen Replacement: paso 12, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to peal back the tape over the wire connector on the bottom of the screen
  13. Gateway ID49C07U Screen Replacement: paso 13, imagen 1 de 2 Gateway ID49C07U Screen Replacement: paso 13, imagen 2 de 2
    • Hold the tape back with one hand and pull the connector out
Conclusión
2 personas más completaron esta guía.
Ryan Howlett
Miembro Desde 03/06/17
267 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 313
