Saltar al contenido principal
Gateway GWTC116-2BL Display Replacement
Qué necesitas
  1. Gateway GWTC116-2BL Display Replacement, Back Panel: paso 1, imagen 1 de 1
    • Ground yourself before disassembling and handling the computer.
    • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
  2. Gateway GWTC116-2BL Display Replacement: paso 2, imagen 1 de 2 Gateway GWTC116-2BL Display Replacement: paso 2, imagen 2 de 2
    • Use the spudger to pry the back panel away from the body of the laptop.
  3. Gateway GWTC116-2BL Display Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the five 3.0 mm Phillips #00 screws.
  4. Gateway GWTC116-2BL Display Replacement: paso 4, imagen 1 de 2 Gateway GWTC116-2BL Display Replacement: paso 4, imagen 2 de 2
    • Using your fingers, flick open the battery connector bracket.
    • Remove the connector from bracket.
  5. Gateway GWTC116-2BL Display Replacement: paso 5, imagen 1 de 1
    • Pull up the battery to remove from the base.
  6. Gateway GWTC116-2BL Display Replacement, Motherboard: paso 6, imagen 1 de 1
    • Using your fingers, flick the cable connector bracket open.
    • Remove the cable from the connector.
  7. Gateway GWTC116-2BL Display Replacement: paso 7, imagen 1 de 2 Gateway GWTC116-2BL Display Replacement: paso 7, imagen 2 de 2
    • Using your fingers, disconnect the black and white connector brackets underneath the gray cable.
  8. Gateway GWTC116-2BL Display Replacement: paso 8, imagen 1 de 2 Gateway GWTC116-2BL Display Replacement: paso 8, imagen 2 de 2
    • Remove the four 3.0 mm Phillips #00 screws located on the motherboard casing.
  9. Gateway GWTC116-2BL Display Replacement: paso 9, imagen 1 de 3 Gateway GWTC116-2BL Display Replacement: paso 9, imagen 2 de 3 Gateway GWTC116-2BL Display Replacement: paso 9, imagen 3 de 3
    • Peel the yellow tape off of the casing.
    • Lift the casing off of the motherboard.
  10. Gateway GWTC116-2BL Display Replacement: paso 10, imagen 1 de 2 Gateway GWTC116-2BL Display Replacement: paso 10, imagen 2 de 2
    • Peel off the yellow tape.
    • Remove four 3.0 mm Phillips #00 screws.
  11. Gateway GWTC116-2BL Display Replacement: paso 11, imagen 1 de 2 Gateway GWTC116-2BL Display Replacement: paso 11, imagen 2 de 2
    • Peel off the black piece of tape covering the display cable.
  12. Gateway GWTC116-2BL Display Replacement: paso 12, imagen 1 de 2 Gateway GWTC116-2BL Display Replacement: paso 12, imagen 2 de 2
    • Flick open the bracket securing the display cable and disconnect the cable from the motherboard.
  13. Gateway GWTC116-2BL Display Replacement: paso 13, imagen 1 de 1
    • Remove the motherboard from the device.
  14. Gateway GWTC116-2BL Display Replacement, Display: paso 14, imagen 1 de 1
    • Remove seven 3.0 mm Phillips #00 screws from the laptop.
  15. Gateway GWTC116-2BL Display Replacement: paso 15, imagen 1 de 1
    • Applying some force, use your hands to pry the display of the laptop away from the base.
Conclusión
Kailey Sousa
Miembro Desde 03/22/24
459 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 37
Todo El Tiempo: 72
