Saltar al contenido principal
Gateway GWTC116-2BL Daughterboard Replacement
Qué necesitas
  1. Gateway GWTC116-2BL Daughterboard Replacement, Back Panel: paso 1, imagen 1 de 1
    • Ground yourself before disassembling and handling the computer.
    • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
  2. Gateway GWTC116-2BL Daughterboard Replacement: paso 2, imagen 1 de 2 Gateway GWTC116-2BL Daughterboard Replacement: paso 2, imagen 2 de 2
    • Use the spudger to pry the back panel away from the body of the laptop.
  3. Gateway GWTC116-2BL Daughterboard Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the five 3.0 mm Phillips #00 screws.
  4. Gateway GWTC116-2BL Daughterboard Replacement: paso 4, imagen 1 de 2 Gateway GWTC116-2BL Daughterboard Replacement: paso 4, imagen 2 de 2
    • Using your fingers, flick open the battery connector bracket.
    • Remove the connector from bracket.
  5. Gateway GWTC116-2BL Daughterboard Replacement: paso 5, imagen 1 de 1
    • Pull up the battery to remove from the base.
  6. Gateway GWTC116-2BL Daughterboard Replacement, Daughterboard: paso 6, imagen 1 de 2 Gateway GWTC116-2BL Daughterboard Replacement, Daughterboard: paso 6, imagen 2 de 2
    • Peel off the yellow piece of tape that is placed over the daughterboard.
  7. Gateway GWTC116-2BL Daughterboard Replacement: paso 7, imagen 1 de 1
    • Remove the three 3.0 mm Phillips #00 screws.
  8. Gateway GWTC116-2BL Daughterboard Replacement: paso 8, imagen 1 de 2 Gateway GWTC116-2BL Daughterboard Replacement: paso 8, imagen 2 de 2
    • Flick open the bracket that connects the motherboard and daughterboard.
    • Remove the connector strip.
  9. Gateway GWTC116-2BL Daughterboard Replacement: paso 9, imagen 1 de 1
    • Remove the daughterboard from the base of the computer.
Conclusión
Kailey Sousa
Miembro Desde 03/22/24
459 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 23
Todo El Tiempo: 61
