Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Introducción
Removal of the system fan. when following the keyboard instructions there is no need to unplug it only fold it back to gain access to the fan.
Partes
No se especificaron partes.
  1. Flip the laptop over. Slide the battery release tab to the right.
    • Flip the laptop over. Slide the battery release tab to the right.
  2. Lift the battery out.
    • Lift the battery out.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove the 5 screws holding the keyboard in place.
    • Remove the 5 screws holding the keyboard in place.
  5. CAUTION: When lifting the keyboard out, do not lift keyboard up. Only fold back along the space bar edge. DO NOT PULL the black cable by the ribbon section; only pull it by the connector itself.
    • CAUTION: When lifting the keyboard out, do not lift keyboard up. Only fold back along the space bar edge.
    • DO NOT PULL the black cable by the ribbon section; only pull it by the connector itself.
    • Follow the black ribbon cable to the connector and gently pull straight up.
  6. Unscrew the 4 captive screws. Unplug fan from the system and pull it out. The fan unit should slide forward before coming free.
    • Unscrew the 4 captive screws.
    • Unplug fan from the system and pull it out. The fan unit should slide forward before coming free.
Conclusión
Equipo
Cal Poly, Team 20-10, Maness Fall 2010 Miembro de Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Miembros
22 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,067
