Introducción
removal of the system board
  1. Flip the laptop over. Slide the battery release tab to the right.
    • Flip the laptop over. Slide the battery release tab to the right.
  2. Lift the battery out.
    • Lift the battery out.
    • Slide release and push button to eject drive
    • Pull drive out.
    • When reinserting drives be sure to insert back into original slot in order to avoid interface conflicts.
    • Unscrew 1 captive screw holding hard drive cover on.
    • slide hard drive to the right and remove.
    • for detailed pictures and info go to Gateway Support
    • Insert spudger between sysrq and ins keys.
    • Gently lift power button panel from the right to left.
    • Remove 5 screws.
    • 4 screws holding LCD hinge covers in place and 1 screw for LCD grounding.
    • Remove hinge covers.
    • Gently unplug LCD from system board.
    • Remove 6 screws holding LCD to hinge.
    • Pull LCD away from case.
    • Remove the 5 screws holding the keyboard in place.
    • CAUTION: When lifting the keyboard out, do not lift keyboard up. Only fold back along the space bar edge.
    • DO NOT PULL the black cable by the ribbon section; only pull it by the connector itself.
    • Follow the black ribbon cable to the connector and gently pull straight up.
    • Unscrew the 4 captive screws.
    • Unplug fan from the system and pull it out. The fan unit should slide forward before coming free.
    • Remove 13 screws from bottom of computer
    • Remove screws
    • remove 4 screws from back of case
    • WARNING Failure to do this step will damage mouse pad ribbon.
    • Lift plug holding mouse ribbon about 1/16 inch or until it stops
    • remove ribbon
    • Insert spudger between upper and lower case at drive bay closest to battery.
    • Carefully and slowly go arount entire case unseating all plastic clips holding upper to lower.
    • Lift upper case free about 1/4 inch
    • At rear of case is one last connecting wire. Unplug and remove upper case
    • Remove 8 screws from drive bays.
    • Remove 6 5mm hex nuts from back of laptop.
    • Remove screw
    • Slide metal clip into battery bay
    • Remove two screws.
    • Hard drive extension should lift out from system board.
    • Remove 4 screws holding left speaker for ease of access to connectors and external sound board.
    • Remove screw and unplug speakers from external sound board.
    • Lift external soundboard away from system board and remove.
    • Unplug audio DJ
    • Unplug System status light board
    • Starting on the right side of case gently lift and slide system board till it comes free of lower case.
Conclusión
Equipo
Cal Poly, Team 20-10, Maness Fall 2010 Miembro de Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Miembros
22 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,459
