Saltar al contenido principal
Gateway 3545GZ Internet Card Replacement
Qué necesitas
  1. Gateway 3545GZ Internet Card Replacement, Internet Card: paso 1, imagen 1 de 1
    • Flip your laptop over and locate the sticker indicating where the internet card is.
    • Using a PH1 Phillips-Head screwdriver, carefully unscrew the screw holding the flap down
    • The screw length is 3mm
  2. Gateway 3545GZ Internet Card Replacement: paso 2, imagen 1 de 1
    • Carefully remove the flap over the internet card.
  3. Gateway 3545GZ Internet Card Replacement: paso 3, imagen 1 de 2 Gateway 3545GZ Internet Card Replacement: paso 3, imagen 2 de 2
    • Unhook the two cords attached to the internet card and remove the card.
    • Next, pull the two metal hooks holding the card in place away from each other.
    • The card should pop out and just take it out from the dock.
Conclusión
Baylee Harding
Miembro Desde 09/12/16
25 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 287
