Saltar al contenido principal
Gateway 3545GZ Hard Drive Replacement
Qué necesitas
  1. Gateway 3545GZ Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Flip the laptop so that the bottom is facing you. You will find in the lower left-hand corner a hole with a small screw; unscrew this with a PH1 Phillips-head screwdriver (Has a plus shape).
    • Screw Length: 3mm
  2. Gateway 3545GZ Hard Drive Replacement: paso 2, imagen 1 de 1
    • Lift up the plastic plate from the outer edge.
  3. Gateway 3545GZ Hard Drive Replacement: paso 3, imagen 1 de 1
    • Finally, slide the hard drive out of its dock; then just lift the hard drive out of the pocket.
Conclusión
Bryan Rickle
Miembro Desde 09/12/16
1 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 279
