Saltar al contenido principal
Garmin nuviCam LMTHD Speaker Replacement
Qué necesitas
  1. Garmin nuviCam LMTHD Speaker Replacement, Screen: paso 1, imagen 1 de 2 Garmin nuviCam LMTHD Speaker Replacement, Screen: paso 1, imagen 2 de 2
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Speaker Replacement: paso 2, imagen 1 de 2 Garmin nuviCam LMTHD Speaker Replacement: paso 2, imagen 2 de 2
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Speaker Replacement: paso 3, imagen 1 de 1
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Speaker Replacement: paso 4, imagen 1 de 2 Garmin nuviCam LMTHD Speaker Replacement: paso 4, imagen 2 de 2
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Speaker Replacement, Speaker: paso 5, imagen 1 de 2 Garmin nuviCam LMTHD Speaker Replacement, Speaker: paso 5, imagen 2 de 2
    • Locate the speaker in the corner opposite of the dashcam.
    • Pry speaker out of device using a plastic opening tool.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 443
