Saltar al contenido principal
Garmin nuviCam LMTHD Motherboard Replacement
Qué necesitas
  1. Garmin nuviCam LMTHD Motherboard Replacement, Screen: paso 1, imagen 1 de 2 Garmin nuviCam LMTHD Motherboard Replacement, Screen: paso 1, imagen 2 de 2
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Motherboard Replacement: paso 2, imagen 1 de 2 Garmin nuviCam LMTHD Motherboard Replacement: paso 2, imagen 2 de 2
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Motherboard Replacement: paso 3, imagen 1 de 1
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Motherboard Replacement: paso 4, imagen 1 de 2 Garmin nuviCam LMTHD Motherboard Replacement: paso 4, imagen 2 de 2
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • Disconnect battery wire from motherboard.
  6. Garmin nuviCam LMTHD Motherboard Replacement: paso 6, imagen 1 de 1
    • Disconnect yellow ribbon cable from motherboard.
  7. Garmin nuviCam LMTHD Motherboard Replacement: paso 7, imagen 1 de 1
    • Pull off black and red wire from screen.
  8. Garmin nuviCam LMTHD Motherboard Replacement: paso 8, imagen 1 de 1
    • Disconnect the orange cable strip connected to the screen using a plastic opening tool, lift white teeth up and slide strip out.
  9. Garmin nuviCam LMTHD Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove silver plate from motherboard.
  10. Garmin nuviCam LMTHD Motherboard Replacement: paso 10, imagen 1 de 2 Garmin nuviCam LMTHD Motherboard Replacement: paso 10, imagen 2 de 2
    • Remove all six 5.74mm screws from motherboard using the T4 screw bit.
  11. Garmin nuviCam LMTHD Motherboard Replacement: paso 11, imagen 1 de 2 Garmin nuviCam LMTHD Motherboard Replacement: paso 11, imagen 2 de 2
    • Lift motherboard out of device using plastic opening tools.
Conclusión
3 personas más completaron esta guía.
Un comentario
Where to buy the replacement mother board? I couldn't find one.
BTW: Nicely done guide.
pitt83 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 638
