Saltar al contenido principal
Garmin nuviCam LMTHD Dash Camera Replacement
Qué necesitas
  1. Garmin nuviCam LMTHD Dash Camera Replacement, Screen: paso 1, imagen 1 de 2 Garmin nuviCam LMTHD Dash Camera Replacement, Screen: paso 1, imagen 2 de 2
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Dash Camera Replacement: paso 2, imagen 1 de 2 Garmin nuviCam LMTHD Dash Camera Replacement: paso 2, imagen 2 de 2
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Dash Camera Replacement: paso 3, imagen 1 de 1
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Dash Camera Replacement: paso 4, imagen 1 de 2 Garmin nuviCam LMTHD Dash Camera Replacement: paso 4, imagen 2 de 2
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Dash Camera Replacement, Dash Camera: paso 5, imagen 1 de 2 Garmin nuviCam LMTHD Dash Camera Replacement, Dash Camera: paso 5, imagen 2 de 2
    • Remove green strip of tape over orange strip.
    • Disconnect orange strip from device using plastic opening tools.
  6. Garmin nuviCam LMTHD Dash Camera Replacement: paso 6, imagen 1 de 2 Garmin nuviCam LMTHD Dash Camera Replacement: paso 6, imagen 2 de 2
    • Unscrew six 5.74mm silver screws using the T4 screw bit.
  7. Garmin nuviCam LMTHD Dash Camera Replacement: paso 7, imagen 1 de 3 Garmin nuviCam LMTHD Dash Camera Replacement: paso 7, imagen 2 de 3 Garmin nuviCam LMTHD Dash Camera Replacement: paso 7, imagen 3 de 3
    • Pop out green plate using plastic prying tool.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 428
