Introducción
Remove the battery to avoid electrocution when working on the device. Be careful to not cut yourself if the screen is cracked.
Qué necesitas
Turn the device off by pressing and holding the power button on the top left of the device.
Using the T5 bit, unscrew the four 5.7mm screws in the four corners on the back of the device.
6 personas más completaron esta guía.
2 comentarios
Thanks for instruction, it helped me a lot, but removing of battery in step 5 makes no sense. The battery stays on the metal plate and does not disturbs for next steps. Of course the cable must be disconnected from the board to make it powerless.
BR
Dennis
