Saltar al contenido principal
Garmin nüvi 3590 LMT Battery Replacement
Qué necesitas
  1. Garmin nüvi 3590 LMT Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the device off by pressing and holding the power button on the top left of the device.
  2. Garmin nüvi 3590 LMT Battery Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to separate the tabs on the black back cover of the device by leveraging the tool against the frame around the perimeter of the device.
  3. Garmin nüvi 3590 LMT Battery Replacement: paso 3, imagen 1 de 1
    • Once all of the tabs are popped out, take the back cover off.
    • The back cover is a separate piece from the device.
  4. Garmin nüvi 3590 LMT Battery Replacement: paso 4, imagen 1 de 2 Garmin nüvi 3590 LMT Battery Replacement: paso 4, imagen 2 de 2
    • Using the plastic spudger, carefully remove the white tab connected to the battery from the device by pulling the tab in the opposite direction from which it is connected.
  5. Garmin nüvi 3590 LMT Battery Replacement: paso 5, imagen 1 de 3 Garmin nüvi 3590 LMT Battery Replacement: paso 5, imagen 2 de 3 Garmin nüvi 3590 LMT Battery Replacement: paso 5, imagen 3 de 3
    • Use the plastic spudger to lift the battery up and away from the device.
    • Do not puncture or bend the battery. Serious health complications could occur.
Conclusión
7 personas más completaron esta guía.
David
Miembro Desde 03/11/15
424 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 35
Todo El Tiempo: 3,529
