Saltar al contenido principal
Garmin fenix 6X Sapphire Display Replacement
Qué necesitas
  1. Garmin fenix 6X Sapphire Display Replacement, Display: paso 1, imagen 1 de 1
    • Orient the watch so that the screen is face up.
    • Remove the five 6 mm black screws from the perimeter of the watch face using the T5 Torx screwdriver.
  2. Garmin fenix 6X Sapphire Display Replacement: paso 2, imagen 1 de 2 Garmin fenix 6X Sapphire Display Replacement: paso 2, imagen 2 de 2
    • Carefully lift up the watch face as it's attached to the motherboard by a ribbon connector.
    • Detach the black connector from the motherboard.
    • A spudger can be used if you have trouble prying the piece with your fingers.
    • Don't pull on the ribbon as it could tear.
    • When the ribbon is disconnected remove the watch face.
Conclusión
5 personas más completaron esta guía.
matthew long
Miembro Desde 02/22/22
522 Reputación
5 Guías creadas
Equipo
Clemson, Team 1-5, Hunter Spring 2022 Miembro de Clemson, Team 1-5, Hunter Spring 2022
CLEM-HUNTER-S22S1G5
4 Miembros
8 Guías creadas
2 comentarios
hello matthew
where could you buy the display. i can't find any suppliers on the net
Mr. Wu - Contestar
Hi! thank you for the tutorial! do you know if a non-sapphire crystal can be replaced with a sapphire one? I got the non-sapphire watch 2 years ago and I keep scratching it.
Dennis Savitskij - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 30
Ultimos 30 días: 170
Todo El Tiempo: 7,223
