Saltar al contenido principal
Garmin fenix 6X Sapphire Back Cover Replacement
Qué necesitas
  1. Garmin fenix 6X Sapphire Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Flip the watch so the face is down.
    • Remove the five 6 mm T5 Torx screws on the back of the watch.
  2. Garmin fenix 6X Sapphire Back Cover Replacement: paso 2, imagen 1 de 3 Garmin fenix 6X Sapphire Back Cover Replacement: paso 2, imagen 2 de 3 Garmin fenix 6X Sapphire Back Cover Replacement: paso 2, imagen 3 de 3
    • Use a spudger to pry the back cover of the watch off by placing it under the seam of the back case.
    • The back cover is glued on and may be difficult to remove. It might help to heat the back cover before prying in order to soften the glue. If doing so, be careful to not burn yourself.
    • This step requires a good bit of force to pry or apply heat back cover off because the back cover is glued. Be careful not to the break cover from too much force.
Conclusión
matthew long
Miembro Desde 02/22/22
522 Reputación
5 Guías creadas
Equipo
Clemson, Team 1-5, Hunter Spring 2022 Miembro de Clemson, Team 1-5, Hunter Spring 2022
CLEM-HUNTER-S22S1G5
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 69
Todo El Tiempo: 2,169
