Introducción
This guide illustrates how to remove and replace the charging port for this device.
Qué necesitas
When looking at the charging port you will notice there are two screws. To remove these, you will need a T4 bit in a nut driver. After you locate these screws you will need to remove them. The screws are 5 mm long.
After the screws are removed, the charging port will lift out of the plastic case.
Una persona más ha completado esta guía.
