Saltar al contenido principal
Garmin etrex Vista Cx Charging Port Replacement
Qué necesitas
  1. Garmin etrex Vista Cx Charging Port Replacement, Charging Port: paso 1, imagen 1 de 1
    • Remove the rubber grip that goes around the side of the device.
  2. Garmin etrex Vista Cx Charging Port Replacement: paso 2, imagen 1 de 1
    • Underneath the rubber grip will also be a piece of tape over the plastic seam. You will need to take the metal spudger and break the tape along the seam.
  3. Garmin etrex Vista Cx Charging Port Replacement: paso 3, imagen 1 de 1
    • Next you will have to use the plastic opening tool and pry at the bottom of the GPS. This will separate the front and the back of the device.
  4. Garmin etrex Vista Cx Charging Port Replacement: paso 4, imagen 1 de 1
    • After the front and back are separated, there will be a small ribbon cable holding them together. You will need to pull straight back on the cable with fingers. This cable will pull straight out.
  5. Garmin etrex Vista Cx Charging Port Replacement: paso 5, imagen 1 de 3 Garmin etrex Vista Cx Charging Port Replacement: paso 5, imagen 2 de 3 Garmin etrex Vista Cx Charging Port Replacement: paso 5, imagen 3 de 3
    • When looking at the charging port you will notice there are two screws. To remove these, you will need a T4 bit in a nut driver. After you locate these screws you will need to remove them. The screws are 5 mm long.
    • After the screws are removed, the charging port will lift out of the plastic case.
  6. Garmin etrex Vista Cx Charging Port Replacement: paso 6, imagen 1 de 1
    • In order to replace the charging port you have to purchase a new one.
Conclusión
Una persona más ha completado esta guía.
Evan Borgman
Miembro Desde 08/28/18
328 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G6, Arle Fall 2018 Miembro de IUPUI, Team S1-G6, Arle Fall 2018
IUPUI-ARLE-F18S1G6
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 217
